correct behaviour? - Printable Version +- Conductive Labs Support Forum (https://conductivelabs.com/forum) +-- Forum: The NDLR (https://conductivelabs.com/forum/forumdisplay.php?fid=1) +--- Forum: General Support (https://conductivelabs.com/forum/forumdisplay.php?fid=2) +--- Thread: correct behaviour? (/showthread.php?tid=1026) |
correct behaviour? - racecube - 07-15-2020 when I am in Motif Edit the NDLR Cntl Channel (default 15) behaves like a Note Input step by step, when I leave the edit then I can change the Chords from I to VII (as specified in KB Cntl) Is this the right behaviour? RE: correct behaviour? - Jesse Johannesen - 07-15-2020 Hi Racecube, yeah that's the expected behavior. That way you can use the MIDI controller as a data entry device for the Motifs. Jesse |
