MIDI TRS Type A/B Question - Printable Version +- Conductive Labs Support Forum (https://conductivelabs.com/forum) +-- Forum: MRCC - MIDI Router Control Center (https://conductivelabs.com/forum/forumdisplay.php?fid=13) +--- Forum: General Support (https://conductivelabs.com/forum/forumdisplay.php?fid=14) +--- Thread: MIDI TRS Type A/B Question (/showthread.php?tid=1578) |
MIDI TRS Type A/B Question - benstat - 06-21-2021 Hi all, My MRCC is currently on order. I'm buying cables while I wait for delivery, but I'm a bit confused by MIDI TRS. I have a 1010 Bluebox mixer which has 3.5mm MIDI TRS in and out ports, and I plan to connect them to the MRCC. Since MRCC has separate ports for both MIDI TRS types (A and B), can I just buy a normal 3.5mm male to 3.5mm male stereo audio cable to connect them? Presumably, if I plug it into the TRS B in and out ports on the MRCC, it should just work given that the Bluebox supports type B for in/out, right? No special cable required (eg. crossover or whatever)? Many thanks, Ben RE: MIDI TRS Type A/B Question - oldgearguy - 06-21-2021 (06-21-2021, 04:28 AM)benstat Wrote: Hi all, Yes - that's exactly what I've been doing. The cable can be generic if you match the port types. I only need special cables if i wanted to cross over A to B or from DIN MIDI to TRS. RE: MIDI TRS Type A/B Question - benstat - 06-21-2021 Great, that's good to know. Will order a couple of cables then. Thanks! RE: MIDI TRS Type A/B Question - Kent - 07-26-2021 Bumping this. I've seen some cables that go 1/8" to 5-pin DIN. Can I use these on standard MIDI I/O (on outputs 11 & 12, say) without regard to type A or B? I don't own any gear with 1/8" MIDI connectors and this new to me. RE: MIDI TRS Type A/B Question - Dark Waves - 07-26-2021 (07-26-2021, 10:39 AM)Kent Wrote: Bumping this. There are many adapter cables for 1/8" to 5-pin, you just need to match the two types, A and B, to whichever type the equipment uses. Some examples: https://www.sweetwater.com/store/detail/ElkMIDI-MnTRS--elektron-ca-3-3.5mm-to-5-pin-din-midi-adaptor-pair https://www.sweetwater.com/store/detail/MIDI-miniTRS--1010music-midi-adapter-male-3.5mm-trs-to-female-5-pin-din Be aware, though, some manufacturers have switched what type is used depending on the model. TRS MIDI Compatibility - 1010music LLC |
