Start/Stop and arming parts - Printable Version +- Conductive Labs Support Forum (https://conductivelabs.com/forum) +-- Forum: The NDLR (https://conductivelabs.com/forum/forumdisplay.php?fid=1) +--- Forum: MIDI Connectivity (https://conductivelabs.com/forum/forumdisplay.php?fid=5) +--- Thread: Start/Stop and arming parts (/showthread.php?tid=1620) |
Start/Stop and arming parts - cee- - 07-18-2021 Hi, My NDLR is configured to receive ext. clock. All works fine, I can externally start and stop the jam and change tempo. However, when I stop ext. while all (or some) parts are playing, there's no way to start over with silent parts. Only if I stop the parts *before* stopping the jam, the parts will be silent on restart. Is there a way to disarm parts prior to starting? Thanks + regards from Germany, cee- RE: Start/Stop and arming parts - Jesse Johannesen - 07-18-2021 I can relate to the frustration on this issue, unfortunately I haven't found a perfect solution to this either, I just tend to end up using NDLR as my Clock source in most situations as a result, it usually saves me a headache. Jesse RE: Start/Stop and arming parts - cee- - 07-20-2021 Good to know that I'm not alone... :-) A simple solution would be to press play/stop repeatedly, and the second press would be the master disarm command. Anyway, keep up your good work, BR, cee- RE: Start/Stop and arming parts - Dirk Offringa - 07-25-2021 (07-18-2021, 11:03 AM)cee Wrote: Is there a way to disarm parts prior to starting? Double stop on the master device disarms all parts Cheers Dirk RE: Start/Stop and arming parts - cee- - 08-13-2021 (07-25-2021, 01:22 AM)Dirk Offringa Wrote:(07-18-2021, 11:03 AM)cee Wrote: Is there a way to disarm parts prior to starting? Only if the master *has* some sort of double stop implemented; afaik it's not a Midi command but just a 'stop' followed by 'all sounds/notes off'. cee RE: Start/Stop and arming parts - Jesse Johannesen - 08-15-2021 I think you just have to press stop twice on the master, no? Jesse RE: Start/Stop and arming parts - Dirk Offringa - 08-15-2021 (08-15-2021, 07:45 AM)Jesse Johannesen Wrote: I think you just have to press stop twice on the master, no? That works for me RE: Start/Stop and arming parts - cee- - 08-15-2021 Tried that, of course, but it doesn'work. Sigh... |
