MRCC Interrogating Routing Destinations - Printable Version +- Conductive Labs Support Forum (https://conductivelabs.com/forum) +-- Forum: MRCC - MIDI Router Control Center (https://conductivelabs.com/forum/forumdisplay.php?fid=13) +--- Forum: MRCC Feature Requests (https://conductivelabs.com/forum/forumdisplay.php?fid=25) +--- Thread: MRCC Interrogating Routing Destinations (/showthread.php?tid=1724) |
MRCC Interrogating Routing Destinations - MickG - 08-27-2021 When trouble-shooting routing problems in the MRCC, it's very easy to check whether or not a source is being routed anywhere in the MRCC - you just hold its source (green) button and any sources (except the Remote7) are instantly revealed. What would be really good would be to add the same functionality for routing destinations. So that you could easily check if a destination was connected to a source. Could this be made possible by using Shift + destination (blue) button? RE: MRCC Interrogating Routing Destinations - Jesse Johannesen - 08-30-2021 I don't think this is something Steve has planned, but you can just have to look at the routing matrix on the Activity Screen, for any destination there is a vertical column which shows connections to any sources (horizontal lines) as colored squares. This makes it easy to identify any routing to a port with ease. The only exception is that the 4 sets of virtual wires of the USB ins and the 12 Virtual wires of the PC port (in and out) appear as single sources and destinations, unless you use the down arrows to look at the virtual port routings. RE: MRCC Interrogating Routing Destinations - MickG - 08-31-2021 Thanks Jesse. Yes, the Activity screen does show overall routing but, as you say, the display of the USB and PC pages is a bit limited. |
