Use USB ports as USB hub into computer so USB audio. Is possible. - Printable Version +- Conductive Labs Support Forum (https://conductivelabs.com/forum) +-- Forum: MRCC - MIDI Router Control Center (https://conductivelabs.com/forum/forumdisplay.php?fid=13) +--- Forum: MRCC Feature Requests (https://conductivelabs.com/forum/forumdisplay.php?fid=25) +--- Thread: Use USB ports as USB hub into computer so USB audio. Is possible. (/showthread.php?tid=1749) |
Use USB ports as USB hub into computer so USB audio. Is possible. - Kyl3wyld - 09-22-2021 If you could turn the usb ports into a standard USB hub there should be no problem using them for audio over usb. Not sure if that would be possible. RE: Use USB ports as USB hub into computer so USB audio. Is possible. - Jesse Johannesen - 09-22-2021 Sorry, that isn't something that we're planning on implementing at this point. It would be pretty cool though, thanks for the suggestion. Jesse |
