MRCC MIDI input 6 use - Printable Version +- Conductive Labs Support Forum (https://conductivelabs.com/forum) +-- Forum: MRCC - MIDI Router Control Center (https://conductivelabs.com/forum/forumdisplay.php?fid=13) +--- Forum: Hardware MIDI Connectivity (https://conductivelabs.com/forum/forumdisplay.php?fid=22) +--- Thread: MRCC MIDI input 6 use (/showthread.php?tid=1890) |
MRCC MIDI input 6 use - QuattroP - 02-17-2022 Hi, Is anyone using the 6th MIDI input on the MRCC? I got my hands on TRS to DIN MIDI cable type A so I tried using the 6th input for the first time. I tried with some synths, connecting the DIN end to them and with the TRS end going into the 6th input. Whatever I do I'm not getting any input in. What am I doing wrong? Thanks! RE: MRCC MIDI input 6 use - oldgearguy - 02-17-2022 Yes, I was using 6 in and out hooked to the Micron and have been sending and receiving regular MIDIand sysex with no issues. My suggestion is to try the B jack in case your adapter isn't really an A. RE: MRCC MIDI input 6 use - QuattroP - 02-19-2022 Tried switching the input around between A & B but no joy...not sure what else to try RE: MRCC MIDI input 6 use - Raphie - 02-19-2022 In 6 trs works fine here, tested with Oxi One to AS-1 on USB 4 |
