Help with a Juno DS - Printable Version +- Conductive Labs Support Forum (https://conductivelabs.com/forum) +-- Forum: MRCC - MIDI Router Control Center (https://conductivelabs.com/forum/forumdisplay.php?fid=13) +--- Forum: MRCC Advanced Configuration (https://conductivelabs.com/forum/forumdisplay.php?fid=24) +--- Thread: Help with a Juno DS (/showthread.php?tid=2038) |
Help with a Juno DS - Mick_D - 10-22-2022 I've got a Roland Juno DS-88 that sounds great for some things, like pipe organs and grand pianos. I have it set to midi channel 8, but it responds to every channel input. After much back-and-forth with Roland, they came up with a way to filter everything else but channel 8 out, but it's an extremely large amount of work on an interface I don't enjoy using. Is there a way for the MRCC to only send midi signals on channel 8 to this keyboard? To block out everything but channel 8? I'm trying to read the manual for the MRCC but I don't really see a way to do this. Anyone got any ideas? RE: Help with a Juno DS - oldgearguy - 10-23-2022 (10-22-2022, 06:40 PM)Mick_D Wrote: I've got a Roland Juno DS-88 that sounds great for some things, like pipe organs and grand pianos. I have it set to midi channel 8, but it responds to every channel input. In theory you would use the Channel Map option. Set Exclusive to "Y", map In: 8 to Out: 8 and set the other 3 inbound channels to "none" (according to the manual). However, as of the most current release, "none" is not implemented yet. Best you can do for now is set In 1: to 8, and In 2,3,4 to another channel like 16 and then use Roland's procedures to block channel 16 RE: Help with a Juno DS - Mick_D - 10-23-2022 OK, thanks, I'll try that. RE: Help with a Juno DS - Jesse Johannesen - 10-23-2022 Or you can use 2 chan maps in a row (both set to exclusive). Set #1 to chans 1,2,3, 8 with traffic going to the same channels, then in #2 have chans 8,9,10,11. Now 1, 2, & 3 will dead end after the 1st CH Map, and the only one to be allowed into #2 is ch 8, so 9,10 & 11 will not pass data either. RE: Help with a Juno DS - oldgearguy - 10-24-2022 That's a good idea RE: Help with a Juno DS - Mick_D - 10-24-2022 (10-23-2022, 09:59 PM)Jesse Johannesen Wrote: Or you can use 2 chan maps in a row (both set to exclusive). Set #1 to chans 1,2,3, 8 with traffic going to the same channels, then in #2 have chans 8,9,10,11. Now 1, 2, & 3 will dead end after the 1st CH Map, and the only one to be allowed into #2 is ch 8, so 9,10 & 11 will not pass data either. Ooh, that's sneaaaaky ![]() |
