MRCC crashes when PC connected - Printable Version +- Conductive Labs Support Forum (https://conductivelabs.com/forum) +-- Forum: MRCC - MIDI Router Control Center (https://conductivelabs.com/forum/forumdisplay.php?fid=13) +--- Forum: Computer MIDI Connectivity (https://conductivelabs.com/forum/forumdisplay.php?fid=23) +--- Thread: MRCC crashes when PC connected (/showthread.php?tid=2301) |
MRCC crashes when PC connected - padsbrother - 05-13-2024 Hi, If I leave my main music-making PC (A Dell Alienware Aurora R10) connected to MRCC into the "PC" port on the MRCC, after a few hours the MRCC crashes and won't respond until power-cycling it. The really strange thing is that this happens even when the PC main power is off. If I use the same cable connected to my laptop, everything is fine! Can someone suggest how I can troubleshoot what's going on please? I've tried rebooting, keeping the PC on and off, different cables, different ports in the PC (front and rear - the rear ones crash less often than the front ones for some reason)... Any help would be much appreciated! Thank you... Jon |
