The Mixer, another great feature with a big mistake - Printable Version +- Conductive Labs Support Forum (https://conductivelabs.com/forum) +-- Forum: The NDLR (https://conductivelabs.com/forum/forumdisplay.php?fid=1) +--- Forum: General Support (https://conductivelabs.com/forum/forumdisplay.php?fid=2) +--- Thread: The Mixer, another great feature with a big mistake (/showthread.php?tid=2339) |
The Mixer, another great feature with a big mistake - racecube - 08-24-2024 You can get to the MIDI Mixer by pressing SHIFT + the lowest Knob on the left side. It generates CC7 on the channels you have assigned your parts to. Works well......BUT: If you use the polychain feature for the Pad it goes only to the Pad channel itself and not to the chained ones. So this is another bug for the list of bugs that did not get shorter fot a very long time meanwhile.... The answer will be: There is no space left in the code to fix that.....as usual... Thank god I have a Blokas MIDIHUB so I can make a workaround and the NDLR can stay in my setup. |
