Modifier slot is freezed - Printable Version +- Conductive Labs Support Forum (https://conductivelabs.com/forum) +-- Forum: MRCC - MIDI Router Control Center (https://conductivelabs.com/forum/forumdisplay.php?fid=13) +--- Forum: General Support (https://conductivelabs.com/forum/forumdisplay.php?fid=14) +--- Thread: Modifier slot is freezed (/showthread.php?tid=3625) |
Modifier slot is freezed - johnleborgne - 05-01-2025 Hello, When making some tests about the transpose issue, I came accross a weird but reproductible problem : modifier stop responding to input, it seems freezed. There is a simple pattern, easily reproductible. One source, tree ouputs. (or 4 outputs) For the first ouput, set a modifiers, I had a T1 modifier. Nothing need for ouput 2 and 3 When you look the MRCC output, output 1 is the left most, the other two came after to the right (this is important, order matters) Now, just remove output 1 from the routing. Try to set a modifiers in the output 2 (which was notmally auto selected), it works. try the same from ouput 3, it won't work anymore. => you have to reselect the output 1 to re-enable the modifiers in ouput 3. If you try this with 4 ouputs routing, the problem will occur on the 3d one again. I made a video if needed. Best John RE: Modifier slot is freezed - Jesse Johannesen - 05-04-2025 Thanks John, can you send me the video? Support@ConductiveLabs.com Jesse |
