Arturia Keystep Midi (Ndlr) - Printable Version +- Conductive Labs Support Forum (https://conductivelabs.com/forum) +-- Forum: The NDLR (https://conductivelabs.com/forum/forumdisplay.php?fid=1) +--- Forum: MIDI Connectivity (https://conductivelabs.com/forum/forumdisplay.php?fid=5) +--- Thread: Arturia Keystep Midi (Ndlr) (/showthread.php?tid=663) |
Arturia Keystep Midi (Ndlr) - Rick_Irregular - 11-05-2019 If I sequenced a part on my Keystep could I play it into the NDLR? RE: Arturia Keystep Midi (Ndlr) - Darryl - 11-06-2019 There are a couple of ways to use an external sequencer or keyboard. You can use The NDLR transpose feature, which will take incoming notes, convert them to the current NDLR Key and Mode, then pass them thru the MIDI output. Another way to use the keyboard or sequencer is with The NDLR Control feature, which offers various ways to change the chord and chord type. You can also use the built in Chord Sequencer to make a sequence of Chords, or use the modulation matrix to change chords, but in a less predictable way. RE: Arturia Keystep Midi (Ndlr) - Rick_Irregular - 11-06-2019 Thanks |
