08-07-2024, 08:04 PM
(This post was last modified: 08-08-2024, 08:57 AM by itdmusic.
Edit Reason: change title
Hello,
I just received a new NDLR and upon starting to learn it found a strange issue
It is related to the change of the pad notes - the range parameter, and then
moving to different chords.
I have the NDLR connected to the computer and using a sequencer and a software synth
and I am recording the midi input that comes from the NDLR into the sequencer.
The p-chains parameter is set to 1, so all the notes should be sent to only 1 midi channel.
The issue is occurring when increasing notes for the pad (the range parameter) and then changing chords.
I started with 3 notes, then increase to 4, change chords, works fine,
then increase to 5, right away I see an additional note, so has 5
but then when I change chord it play a 3 note chord
then I decrease the notes back to 4 and now it is playing 4 notes
then I repeat the whole thing and the same issue.
Firmware is 2.0.011 (I did not update to the newer one)
I discovered that this happens when the spread is 2 or above
when it is 1 and I increase notes, it always work (I went upto 7 notes)
I am attaching a screenshot of the midi recording with an explanation
of each step I did, and would like to ask about this strange issue.
Thank you
Thank you
