Pad Latch/Unlatch?
I'm really enjoying NDLR, but have a question about Pad mode. When one engages Pad mode, it remains latched until play stops. Is there any way to have the Pad mode only play as long as a given chord button is pressed and release as soon as one stops pressing? In some contexts, it's more musical to have a Pad play continuously; however, in other contexts, it would sound more musical to my ears if a Pad could be released and decay naturally each time one presses and releases a chord button. Is there any way to accomplish this currently without having to constantly turn Pad mode on and off manually via Play/Pause? Perhaps a Pad latch/unlatch parameter?
Hello, we typically control the length of PAD notes with the synth. You can use a patch with a shorter release, or edit the release time to shorten the notes. However, this would be a good feature request for the feature request section.
