is this a behavior ok ?
Since I’m having trouble to control Chord type/degree from external Keyboard with newest firmware I came with alternate cool method for NDLR to play two chords automatically:
1. Pick a mod slot and set it to 8 or 16 bars Square
2. Set destination to the chord degree
3. Set the range to go between 1-IV (0-2 or C<->F in C major)
4. Set the drone trigger to be chord based type (follows the chord degree) and activated on the first 1/4 note)
5. turn on PAD,DROne and perhaps one Motif
6. The chord degree changes every 4/8 bars and Motif and Pad play nice changing degree
BUT!t The Drone is delayed by half of bar with the chord note change
Bug or desired behavior or I don’t know what I’m doing
The desired behavior is that all 4 parts change the chord degree at the same time
thanks!
