06-09-2021, 06:55 AM
Hi
Im trying to use NDLR in a mixed hardware and VST environment over USB MIDI using Logic Pro X
I want to connect NDLR to Logic via USB and control hardware and software using Logic as the hub routing MIDI data to each instrument. I also have a MIDI controller keyboard controlling a Novation Peak over USB via Logic and also a Matriarch, a Drumbrute impact and a Pro 3 SE synth connected (all using Logic as a hub with audio routes in via a focusrite 18i20).
The Matriarch is MIDI ch 1, the Peak 2, Pro 3 SE, 3, the Drumbrute is ch 4. The VST’s are on another channel. My usual set up without NDLR is connected this way so I can perform with multiple instruments that are played or sequenced (usually on the device itself rather than Logic) and synced, mixed and recorded in Logic. I don’t yet use Logic to record midi tracks to control the devices but, of course, could by creating MIDI tracks and printing the audio.
In this case, I just want to play all the instruments using NDLT through Logic over USB instead of manually playing and sequencing in the devices themselves.
Can this be done without using MIDI DIN connections? If not, is it a problem if I also connect the devices with DIN cables (with them still connected to the DAW with USB)? Do the MIDI channels on NDLR need to match the virtual channels set up in Logic?
I did ask Jesse and got a great response but wondered if any form users had experience with this kind of set up. I tried to cut and paste it here, unsuccessfully. It certainly sounds theoretically possible.
Andy
I have three hardware synths. One is controlled via logic and is a module (Novation Peak). The other two are a Matriarch and a Pro 3 SE respectively.
Each is on a separate MIDI channel, connected to the DAW (Logic) with USB.
Can I connect NDLR to logic via USB and control both VST and hardware instruments through logic, or do I have to physically connect each synth to NDLR with 5 pin MIDI cables?
I’m hoping to use virtual MIDI channels with logic as the hub. Is this possible?
Matriarch is ch 1
Peak is ch 2
Pro 3 is ch 3
Each VST is on a different channel…..
MIDI controller keyboard controls peak and, when activated, each VST.
I havI have three hardware synths. One is controlled via logic and is a module (Novation Peak). The two are a Matriarch and a Pro 3 SE respectively.
Matriarch is ch 1
Peak is ch 2
Pro 3 is ch 3
MIDI controller keyboard controls peak and, when activated, each VST.e three hardware synths. One is controlled via logic and is a module (Novation Peak). The other two are a Matriarch and a Pro 3 SE respectively.
Matriarch is ch 1
Peak is ch 2
Pro 3 is ch 3
Andy
Matriarch is ch 1
Peak is ch 2
Pro 3 is ch 3
Matriarch is ch 1
Peak is ch 2
Pro 3 is ch 3
Matriarch is ch 1
Peak is ch 2
Pro 3 is ch 3
