Behringer RD-6 Midi sync issue
Hi, I am having trouble getting the RD-6 to sync using Midi DIN cable. I have the following setup:
- Midi clock coming in on midi DIN port 1
- port 1 routed out to ports 1-4
  - out port 1 routed to CV-OCD to modular (no filters): OK
  - out port 2 routed to TR-8S: (output filters enabled so only clock and start/stop are sent): OK
  - out port 3 routed to Cyclone Analogic TT-303: (output filters enabled so only clock and start/stop are sent): OK
  - out port 4 routed to Behringer RD-6: (output filters enabled so only clock and start/stop are sent): DRIFTS AFTER 3-4 BARS
I've also tried disabling the output filters, and I've tried other out ports and I get the same behavior.
One other thing to note, the MRCC freezes when I attempt to connect the RD-6 via USB to the MRCC midi in/out port A.
I verified the RD-6 syncs just fine when I connect it to the thru port on any of the other devices synced to the MRCC listed in the configuration above.
MRCC firmware version: 1.1.035
thanks,
Ben Berman
