Midi clock from daw to analog clock out
(11-10-2024, 01:06 AM)ws05 Wrote: Any update on this request? Or is there any way to use the din sync clock/run cable to output din signals from one of the mrcc outputs?
Actually I guess on my part this is a few requests:
1 - be able to configure DIN outputs to "din sync" output (/24 and run signals)
2 - be able to select a single source input for the internal clock from one of the inputs, and use that as the clock for every output
Would be amazing!
Looks like I found the correct thread to tell me what I seek is not available. I just made an account to voice my want for this method as syncing to a MIDI clock signal generated by the audio clock on my DAW is what I would really like to merge to various MIDI outputs on through the MRCC. Please add to feature request.
I don't think we'll be able to accept analog clock in any time in the near future, as the MRCC doesn't have a port for that, but I am currently pushing to see if I can get syncing MRCC clock to an external source, which allows for syncing downstream modular and analog sync devices to upstream devices. Fingers crossed.
(01-30-2025, 06:43 PM)Jesse Johannesen Wrote: I don't think we'll be able to accept analog clock in any time in the near future, as the MRCC doesn't have a port for that, but I am currently pushing to see if I can get syncing MRCC clock to an external source, which allows for syncing downstream modular and analog sync devices to upstream devices. Fingers crossed.
Any external MIDI clock sync passthrough or reclocking that doesn't require routing to every destination would be very nice.
