Modulation Matrix Problem
Hello Everybody
I have noticed a problem with the modulation matrix
I use LFO1 (with default settings) to modulate Pad Position
The Mod amount is 25%
The Mod range is 20 to 44
The range of Pad is 1 note
It works fine when I push button I : notes are played one at a time
But when I push button II , notes from the previous chord are stuck
I have checked with MidiOx and it seems that some "Note off" events are missing
TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT
    940038  1  5    147    52  127    4  E  3 Note On
    940163  1  5    147    48  127    4  C  3 Note On
    940164  1  5    131    52    64    4  E  3 Note Off
    940664  1  5    147    43  127    4  G  2 Note On
    940664  1  5    131    48    64    4  C  3 Note Off
    941039  1  5    147    40  127    4  E  2 Note On
    941040  1  5    131    43    64    4  G  2 Note Off
    941539  1  5    147    36  127    4  C  2 Note On
    941540  1  5    131    40    64    4  E  2 Note Off
    942039  1  5    131    36    64    4  C  2 Note Off
    942039  1  5    147    40  127    4  E  2 Note On
    942539  1  5    131    40    64    4  E  2 Note Off
    942539  1  5    147    43  127    4  G  2 Note On
    942913  1  5    131    43    64    4  G  2 Note Off
    942914  1  5    147    48  127    4  C  3 Note On
    943414  1  5    131    48    64    4  C  3 Note Off
    943414  1  5    147    52  127    4  E  3 Note On
    943789  1  5    131    52    64    4  E  3 Note Off
    943790  1  5    147    55  127    4  G  3 Note On     => this note never gets a Note Off event
    944788  1  5    147    53  127    4  F  3 Note On
    945289  1  5    147    50  127    4  D  3 Note On
    945289  1  5    131    53    64    4  F  3 Note Off
    945789  1  5    147    45  127    4  A  2 Note On
    945789  1  5    131    50    64    4  D  3 Note Off
    946060  1  5    131    45    64    4  A  2 Note Off
Maybe I am doing something wrong
Anyway , thanks for reading
Have a nice day
Alain
Thanks for reporting this. I'll see if I can get it to reproduce on my end and make an issue in the bug tracker.
I tried this out last night per description here. There was a stuck note every time I changed chord degree. I found this odd because I modulate the Pad position a lot. Or, to be emphatic, A LOT. And, rarely, if ever, have stuck notes. The only difference I found was the modulator. In this example, it is LFO1 (mine was set to Uni 5.0s tri) that fails every time. My typical use modulator is MOD2 BiPol 48 beat sine that never, or rarely, gets stuck notes.
The modulator, or the rate, may be key in differentiating success or failure. Definitely more experiments are needed, but this appears real to me.
