Destination Value for CC Modulation
I've noticed that when you set the mod destination to a MIDI CC the dest value is replaced by the MIDI channel.
You should find a way to keep the destination value also for CC mods cause they are quite useless without it.
An option could be to use the SHIFT together with the knob to set the Channel instead of replacing the dest value.
Thank you,
bless,
Claudio
