01-20-2024, 05:04 AM
Hi I am trying to set up an Elektron Model:Samples in Abelton and control it of the Midi plugs vs USB through the MRCC. I have assigned it to P3 ->3 and 3->P3 but am having a few issues. The Samples uses a midi channel for each of the sample tracks 1-6 (T1-T6)as well as 7 for FX and 8 for Program change.
No matter what I do adjusting any of the knobs on the Max4Live plugin only ever effect s Channel 1 (T1) Is the MRCC only capable of outputting to one channel on each of the MIDI ports? The assumption if I should be able to select the sample track and adjust from the plugin.
It's also super annoying that the ports are not able to be given names or be numbered at the very least.
