05-04-2021, 08:58 AM
		Hey all, first my apologies if this is something I am missing but I am not even sure what search terms to use to search for.  I will explain my problem.
I have the NDLR connected by USB to my computer. I have Ableton Live, Cakewalk, and Midi Ox that has produced this issue.
I have the NDLR set to send midi out of USB1 which shows up in all the software as NDLR. Motif 1 goes out channel 1, Motif 2 goes out channel 2, Drone goes out channel 3, Pad goes out 4 and has P-Chains enabled (4) so there is also MIDI data going out channels 6 and 7 (not sure what happened to 5 but that is not of particular importance right now).
If i select the input and output from any software I have, it seems to make a loop and the NDLR is repeating the same MIDI messages it is sending out. I am not really sure what to make of this as I have a good bit of hardware and have not seen this particular issue before. If this is happening with other hardware they seem to be ignoring the looped data they have sent that gets returned to them.
Is there a setting or something that I have missed? I have tried the last two firmware release versions and the current beta for the NDLR and the problem (or my lack of knowledge) seems to exist across all of them.
If I disable the MIDI send in the software, the problem goes away but I cannot send any MIDI to the NDLR.
I hope I have worded this in a way that makes since. Any help or pointers will be greatly appreciated.
Bryant
Bryant
