chord sequencer - associate a program change
In the bottom part of the chord sequencer as you input A-1  A-2  B-1  B-2  C-1 etc  would be great to be able to repeat one of them but with a program change, e.g. add the program (sound) for each item in the sequencer. That way I can do A-1 (bell) B-1 (guitar) A-1 (harp) etc...
I guess the complexity is what part do you want to change to apply to (drone, pad, motif). so its probably not the simplest feature.
Or maybe work it from a midi-in to change a part so you can at least drive it from a keyboard. Add a screen so that upon receiving a midi event you set the part and program change.
I was thinking about something similar but more limited and still useful: the possibility to add as "chord" block within A/B/C a block without notes in which you can specify which of the parts are muted.
