03-13-2021, 07:47 PM
There are 2 hardware versions, (well 3 but the last two are basically the same for the purposes of this discussion) the first round of hardware had free rotating encoders, the latter version has clicky (detented) encoders. The issue being discussed is due to the fact that both hardware versions need to run the same firmware and it was difficult to edit small values with the free rotating encoders since they don't let you know with a click when they've moved to a new value, so we made it so you have to go a couple or a few values for some things so that you don't constantly go past where you meant to when editing on a version 1 unit.
If the unit you get is a version 1 unit it won't have the issue because it will have free rotating encoders, but those are also easier to bump and change a value than their clicky V2 cousins, so it's kind of a pick your poison situation. I use a free rotating one myself and I don't really have any complaints, but it also doesn't bother me that much that I have to click a couple times for some things on V2 hardware either so I would be happy whichever way it turned out.
I am putting together a list of things I want to try to address in future firmware updates, and this is definitely near the top if we can find a way to do it. No guarantee, but I see the need and I will advocate for finding a solution.
Thanks,
Thanks,
