Computer Port Names are now "MRCC" only
#11
On Mac, You can deal with it , even if the procedure is a bit tedious : you can create and name midi devices for each MRCC virtual in and out port in Apple's Audio Midi Setup application. When linked to the corresponding MRCC Midi Device ports, applications such as Midi Patchbay and Midiflow (IOS but it works flawlessly on Desktop to) will recognise these Midi devices and the replace the twelve anonymous MRCC port with correct labels. It's a workaround :-)
Attached Files Thumbnail(s)
Thanks Tielemat, I'll see if I can have Darryl mention this in the FAQ, that's good info.
Do you think you can send that image to me at support@conductivelabs.com? It's only showing up as a thumbnail for me here.
