Use with Studio One
#11
(04-27-2025, 11:18 PM)Royce Wrote:
(04-11-2025, 02:53 PM)TBrett Wrote:
(04-11-2025, 01:02 PM)Jesse Johannesen Wrote: If I remember correctly, we had been doing something which was problematic with the way things enumerated a while back which mostly caused problems with Apple, but mainly when using 2 devices. Are you on the latest beta firmware? As you may have seen we recently took a good deep look at our USB enumeration and port naming and I think we're pretty confident that naming issues are fixed on our end. It's always possible that I'm wrong, but I don't think there is anything we're doing that would prevent the ports from showing up in normal (correctly implemented) use cases. You my reach out to the Studio one devs and ask them to get in touch with us (support@conductivelabs.com) and we can see if there's anything we can do to steer them in the right direction.
Hi TBrett,
If you are using a PC you can run MidiOx and set up MidiIn and MidiOut of any/all MRCC PC ports  as Midi devices.
If you are using earlier than Win10 this setup prevents the MRCC Ports being connected to other applications because the early Microsoft standard driver was "single client", but... loopMIDI is "multiclient" and can be connected to any number of applications.
You can use MidiOx to connect the MRCC to loopMIDI a system of virtual (free software) l MIDI cables
Install loopMidi and set up a few virtual cables (you can add more later). Name them loopMRCC1in, loopMRCC1Out, loopMRCC2In, loopMRCC2Out etc
Start MidiOx and go to Options/Midi Devices and setup the MRCC Ports you need and add the loopMIDI virtual cables you have setup..
In MidiOx create connections between the MRCC ports and the loopMIDI cables in the Port Routing window (menu View/Port Routings - left side are the MIDI inputs so drag one to the outputs on the right side to make a connection)
MRCC1In-> MidiOx ->loopMIDI1In : MRCC1In data will be sent out loopMRCC1In
and
loopMRCC1Out-> MidiOx ->MRCC1Out : loopMRCC1Out data will be sent out to the MRCC port MRCC1Out
Open Studio and make the Midi In "loopMRCC1In"
Open your other applications and also make the Midi In "loopMRCC1In"
Do the same for the MidiOut connections . Use loopMRCC1Out.
Hope this helps
Royce
Thanks for the reply. I'm running w11. I have midiox, I was trying to use it with an ESI mu8x which I bought initially, as I was originally going to go dawless, but gave up on that lol. The esi doesn't have it's own software, so was trying to use midiox for that but found it a bit hard to use. I will have another go with the mrcc. Another question though, I could use the ESI alongside the mrcc? w11 aloows multiple seperate midi interfaces? I still have it, and was considering selling it, but if I could use it as well it migh be owrth keeping.
Yes, Windows allows more than one MIDI interface (I'm not using W11, but it shouldn't be that different). They should show up as options to any application, but it's probably a limitation of the software whether they can support multiple interface devices. My guess is that should work in most cases (it would in Ableton for instance).
(04-28-2025, 02:06 AM)TBrett Wrote: Thanks for the reply. I'm running w11. I have midiox, I was trying to use it with an ESI mu8x which I bought initially, as I was originally going to go dawless, but gave up on that lol. The esi doesn't have it's own software, so was trying to use midiox for that but found it a bit hard to use. I will have another go with the mrcc. Another question though, I could use the ESI alongside the mrcc? w11 aloows multiple seperate midi interfaces? I still have it, and was considering selling it, but if I could use it as well it migh be owrth keeping.
Hi Brett,
if you need any help with MidiOx pop over to the Midiox Forum. http://www.midiox.com/cgi-bin/yabb/YaBB.pl
I am an administrator there and I would be happy to try and help you out.
Royce
Hi Brett,
Royce
SO I set up loopmidi, and got as far as the port routing screen in midiox, but the inability to scroll is a shame, can't see all the ports. I did read through the midiox forum and saw your advise to run 2 instances of midiox, but TBH it's getting a bit complicated for me.  Going to try the ESI on one synth and see if it will let me run and editor plus studio one, but it could well be a studio one problem anyway. Thanks for your help
3 Guest(s)
