Greetings,
I've noticed that Pad notes occasionally get stuck while changing chords. In troubleshooting this the Pad range was reduced down to 1 note but oddly the NDLR sends two different Note On messages (which seems like a bug?). After a chord change it sends a single Note Off message, leaving one note hanging.
The Panic function doesn't kill it. Have to power cycle the sound module or temporarily switch to a different patch. This appears to occur frequently and is fairly repeatable. Am running the latest FW release. Like Spread thinks there's more than 1 available note to play...
Had also experienced some other strange behavior with Pad, where by Poly-Chain was set back to 1 but the display would display Pad (+3). Power cycling doesn't clear this out either. The only thing that I hadn't done was reset it back to factory default settings...
My apology is this was already posted, hadn't checked recently.
