07-20-2021, 02:34 AM
So I forget -- when I create new labels, they are automatically saved in the master list of labels. Also, I cannot delete any of the factory labels even though I'll never use them, right?
When I use the Assign labels to ports menu, it appears that these label assignments are lost on power down. The only thing I can guess is that I needed to save the routing patch I was using which means label assignments are on a patch-by-patch basis???
If that's true, I'd like that changed to have label assignments saved globally. The whole point of a patchbay is that you dynamically change the patching, you don't dynamically change what is being patched. The only time I edit labels on my Sycologic 16x32 is when I add or delete a piece of hardware. I create and assign labels globally; routing information is saved with the patch. The MRCC should also work this way.
(this is not a complaint based on losing an hour+ of work because I now have to reassign 34 input labels and 28 output labels for both MRCCs. Really, it's not. It's a complaint for the next time it happens)
