08-10-2021, 01:29 PM
Hi there,
after spending some time with the MRCC and being a hardcore MIDI Patchbay user (mainly MIDITemp MP series, iirc not known in USA, but in Europe) I think the MRCC is up until now the device that gets the closest to the MP series and add some modern features, but still leave a lot do be desired.
If I should split up that text in 2 parts, one for the feature requests, please let me know.
I will not comment on the hardware, since that cant change for now, so I focus on the Firmware. Here are my thoughts:
Ideas/suggestions:
- default display page should be preset and selector, not activity
- Routing DIN ports should have a special mode or should be not so easy to adjust, like hold input button
- Naming of presets possible?
- Preset save load should be at main page too
- Why no routing adjustment in the second page?
- Is there a routing overview page?
- Port Naming as interface could be better
- Port Names are not seen in MacOS Audio MIDI Setup
- Should show display actions while doing routings, ATM it’s somewhat blindfolded, especially when routing USB ports
- is there a Port Reservation function for USB Host ports? If no, there should be, like on iConnectivity interfaces
- Sysex filter is missing
Ideas/suggestions:
- PC Filter should include both bank controllers, independent of CCs
- Add a shortcut mode for preset select, like holding Y and typing in numbers
- Add USB storage support for USB sticks
- add a backup function for an USB stick on host ports
- add USB Host port reservation feature
- Add a Sysex filter
- Since Note modifiers can be used for drum maps, so please add a drum map feature with cakewalk style maps to import (simple text files)
- Labels should be saved independent from a preset (global)
- Combine channel mapping with channel to port mapping, so a channel can be mapped differently to different outputs
- Velocity processor should be port based also
- Note Alter should be port based also
- In addition to Ports install a device management. Each device gets a Name, descriptor for Clock send, Receive or Clock Priority and it then can be assigned to a port. If you rewire your setup you don’t have to reprogram the complete routing, just assign the device to another port
- Virtual cable Feature. Instead of assigning filters and remaps to a certain port or channel it can be assigned to the specific connection between 2 ports.
- Panic function should have a label on the case
- Add a button/panel lock function
- Add a startup delay for devices that take longer to boot and should receive commands
bye,
Dietmar
bye,
Dietmar
