06-06-2022, 08:57 PM
(This post was last modified: 06-06-2022, 09:27 PM by Nelson Baboon.)
i haven't been using usb connections of late (mostly because i no longer have the devices that i set up that way).
seems pretty simple. I tested this keyboard connected to the mac usb and my midi monitor shows that it is sending out midi data. I connect it to mrcc, and the mrcc powers it up. I connect the usb cable to the usb a port. i hold the in button and select port 1 for it. I then choose the output din port to receive the midi. Nothing. I have one synth that has a midi monitor on it - it verifies that nothing is being sent. am i forgetting something about the connections?
i figured that this would work because it's big brother (forget what length keyboard) is touted as working in the section about usb compatibility.
Edit: i couldn't believe that it was the logic of my connections....so i noticed in the thread about devices that worked, that the norand mono works with usb. connected that into the usb a port. nothing. note that in my testing of the keyboard, i power cycled the mrcc to no effect. ok - i checked my connections over and this should work. Power cycled the mrcc and voila - the norand then sent out midi through the mrcc. plugged in the keyboard. nothing. power cycled the mrcc again, and now the keyboard is working. not sure why it didn't at first, despite power cycling the mrcc. but it does seem to work, so my cheap little keyboard can be used.
