Greetings,
Am attempting to route the NDRL thru MRCC to Polyend Poly 2 (MIDI to CV module). The issue is that Poly 2 recognized just 1 of 4 parts (Motif 1).
The NDLR is connected via USB to HostA and Poly 2 via 5-pin DIN. (No other routing issues have been encountered with other gear connected to MRCC).
If NDLR is plugged directly into Poly 2 via USB then all parts are recognized on Poly 2. And if a MIDI controller keyboard is routed to Poly 2 (via 5-pin) it also recognizes CC's over the same 4 MIDI channels; which tells me it's not a Poly 2 configuration issue.
Suggestions? I appreciate any assistance you can offer.
Regards
EDIT: Figured it out.. Forgot to define each of the virtual ports on HostA port. Of course it didn't dawn on me until after hitting the submit button
Regards
