Screen gone Black after Firmware Update - Solved
Owen, thanks for getting in touch with us, we'll get that sorted out with you through the support email. Cheers.
I just bought a NDLR today (my second), and it was still on very old firmare but working. I applied the latest, and it boots up, shows the splash s creen with the 1.1.86 version, and then the screen goes black. Tried reflashing it a couple of times, but same problem each time :-(
NM a factory reset was all that was needed. Leaving this post here in case others find it useful.
(09-07-2024, 01:28 PM)geekraver Wrote: NM a factory reset was all that was needed. Leaving this post here in case others find it useful.
Ran into the same issues after an upgrade to 1.1.86. Booting with Shift/Menu pressed allowed me to do the factory reset. Probably would be a good idea to add this information to the Troubleshooting section on the Update page.
Good call, I'll see if I can get that added.
(09-09-2025, 08:17 AM)Jesse Johannesen Wrote: Good call, I'll see if I can get that added.
It's added. Thanks for the suggestion!
5 Guest(s)
