07-03-2020, 09:55 AM
(This post was last modified: 07-07-2020, 04:43 PM by Scotty_123.)
This issue only appears when you are setting the clock divider for Motif 1 using external CC control - Motif 2 works as expected and reliably
On Motif 1 when you change the clock divider with the hardware knobs on the NDLR the divider maintains sync as you would expect.. it shifts seamlessly between all six clock divisions and the timing is locked to a grid. Perfect.
On Motif 1 when you change the clock divider with CC control Motif 1 loses sync to the timing grid. You may have to do it several times alternating between the settings via CC before it becomes obvious. It is much easier to notice it when you have a drum pattern playing... This issue does not impact Motif 2... motif 2 always keeps a lock to the grid no matter how many times you change the clock divisor using CCs.
If you can't replicate this I will post a video on Monday.
