07-07-2020, 01:45 AM
Is there a way to set note duration for the NDLR parts?
Or is it presumed that this will be taken care of in the synth voice?
Setting note duration...?
07-07-2020, 06:39 AM
(07-07-2020, 01:45 AM)six_wax Wrote: Is there a way to set note duration for the NDLR parts?Hey again, There isn't really any definitive way to adjust the note length within the NDLR, you are correct that this is something presumed to be taken care of on the synth voice, however again it is possible to utilize the Mod Matrix to adjust the decay time or release time on the downstream synth via MIDI CC. This is another area where using the Patterns as LFO shapes can be really rewarding. You can even edit the patterns using the pattern editor ([shift + MENU] then press the top right encoder button to get to this menu) in real time while they're being used to modulate things. Jesse |
« Next Oldest | Next Newest »
| 2 Guest(s) |
