07-20-2020, 03:43 AM
I've noticed that in chord sequencer you have to set the Key & Mode, would it be possible to lock it to the key & mode you select when using encoder 4?
A copy/paste function would be nice for the sections, so you don't have to set length etc everytime (would only need to change chord values).
It seems that when you stop or pause a part, upon pressing play, the chord progression does not start over (unless you are on chord sequencer page). I'd like a setting where the chord progression starts from the beginning.
