Threads: 10
I chained 4 synths with the "Pad Chain" feature, and I put the sum of their voices for Pad Range - 19. While the pad is playing, I see that number of notes changes without user input, it went to 20, 24, 29. Is this the expected behavior, or am I using this wrong? I also set up a Mod 2 BiPol with target Pad Position.
Threads: 10
I meant to say, if I have 2 synths chained who are each 4 voice polyphonic, would I set Range to 8?
4
Ah, I see. Yes that is the way I would go about it as well. I did a little testing yesterday and by moving the position to one of it's extremes does impact the number of voices, but I wasn't able to get it to change more than 1, (so if we have a range of 8 then going to either end of the position results in a temporary range of 7 notes.) I can't think how else that number could change without the modulation matrix being the source of the change. I would start by double checking that this isn't accidentally being targeted somewhere in the Mod Matrix. Other than than I don't know what else would cause that besides user input. A real head scratcher.
