03-26-2021, 06:20 PM
(This post was last modified: 03-26-2021, 06:25 PM by Ghostz_of_Moar.)
.(I mean somebody had to use the precious space where the os resides to put this beta feature in...)...lol.
I do have an idea as per how to deduce it’s effect on the output.
I have an mv8800 and I could try recording the midi phrases into patterns and try and see the differences when the function is set to on or off. Do you have similar technology at your disposal?
Thanks all! I am dying to hear more about this. In the meantime I am going to give it a try this weekend with all this new info available.
8
OK so I talked with Steve and got the lowdown on this Easter-egg. So as I mentioned before it works in conjunction with pattern number 40, and specifically the first 5 values of pattern 40 correspond to the Parallel interval and the 4 rotating intervals.
This means that for any note you play (I imagine on the transpose channel, but forgot to ask) it do the following:
1 Play that note,
2 Play the note that is the parallel interval up from that note
3 Play the note that is the next rotating interval from that note and
4 move the rotating note forward 1 space in the list.
So any note played elicits 3 separate notes out, 2 will always be the same interval apart, one will change interval per note played.
Let me know if that makes sense or if I need to take another whack at describing it. meanwhile I'll check what the input channel is and see if I can clarify that.
