06-23-2021, 08:28 PM
Hello!
I had a chance to do some initial playing on the MRCC this week. It is fantastic! Super high quality all around. The look, feel, funtionality, UI... everything I have come to expect from you guys!
I love the options for screen and LED settings. However, I have a small, but important bit of feedback from someone who has a medical condition that is highly affected by intense lighting. The LEDs have brightness settings from 1-10 which is great! However, even at 1, they are still way too bright. I think the front, large lightpipes intesify there brightness as the smaller light pipes towards the rear (USB ports) are much less intense.
I would suggest if possible to offer a lower setting where the brightest LEDS (selected ports) are the same brightness as in setting 1 as ports that are active in routing but not the selected ports (the dimmed ones - I hope that makes sense). I would then make the non-select ports (dimmed ones) be 1/3 less bright or something so that they still show dimmer than the selected port. Or maybe it is possible to add more levels - say another 10 and put make the current level 1 as the middle brightness and then the rest dimmer going down from there.
Right now, I have to cover them with masking tape for me to be able to use the device, which takes so much away from the beauty.
I hope this is acheivable with firmware.
And seriously - I know I said this already - this instrument is just beautiful and way exceeded my expectations!
Michael...
Michael...
