06-26-2021, 01:56 AM
Hey all,
... as a proud owner of a MRCC, which I received a couple of days ago, I tested some of my USB-Midi gear. Now my question.
Is there a kind of hand-shaking or switch-on procedure, which I should consider, when I plug in new gear in USB ports?
Background:
My Keystep worked instantly on the MRCC, but my Pyramid needed some attempts, before it was accepted. I cross-checked the Pyramid without changes with my MPC, connected it to one of the USB ports and it was plug'n play as expected.
I wouldn't call this an issue, but it makes me wonder:
Background:
- should I first power up the MRCC, then connect unpowered USB gear, and finally switch on the gear,
- or should I have MRCC with power off, connect all gear, and power on MRCC as the last,
- or doesn't such a procedure matter at all
