Hello,
I had the same boot error. I opend my stored preset on my PC and found strange connection entrys with Ports "-1" in "[connection015]" to "[connection020]":
[connection015]
inputPort=-1
outputPort=-1
[connection020]
inputPort=-1
outputPort=-1
I deleted all these entries, adjusted the connection count in the second line and was able to load the preset without issues.
Greets
Hi there all,
I have a temporary fw fix for any of you who are affected by this particular issue. Steve is still working on the root if the issue, but we have a firmware that will sidestep the symptom (Basically prevents the -1 from causing boot errors) until we can fix the issue at the source. If you have had this issue please email me at support@conductivelabs.com and I'll send you the file.
Best,
I have been busy with other things, so I didn't see the updated firmware until this morning. Happy to report it fixed the issue for me. It's booting as expected, and clock parameters are being recalled as set.
Thank you! Great job fixing this!
I experienced the boot failure and the .29 firmware fixed it with an exception. it hangs in a different spot when i have my sensel morph plugged in while booting. if i unplug it, it boots fine and then works fine once i plug it back in. i see there's a .30 available now and I'll give that a try.
Glad to hear the update solved that issue (mostly). Can you tell me which point it freezes in the process with the Sensel? The light's indicate different points in the boot process, so knowing might help provide some insight as to what is going wrong.
