Chord Sequencer Timing
I'm having issues with the Chord Sequencer & timing.
I've set things up as simple as possible to highlight the issue. NDLR is the master and my DAW is sync'd to it. I press play on NDLR and the DAW starts playing. Next, I have simple 4 step Chord Sequence with each set to 4.0 length so each chord should play for 1 bar.
However, this is not what happens. If I record the Midi then I can see in my DAW that the first chord only plays from 1.1.1 to 1.4.3. Each subsequent chord does play for 1 whole bar, but they are all out by 0.0.1 because of the first chord.
I double checked all the Chord steps and each are set the same (4.0).
I can make this work by making the 1st Chord 4.5 but then as the sequence loops, this additional 0.5 length throws everything out again.
I'm assuming this is a bug?  Huh
