Its possible to connect 2 MRCCs together using a CAT6a shielded Ethernet cable to enjoy remote routing and lots more ports. But can you use a Remote 7 too? Yes you can, with a custom RJ45 splitter!
In this configuration, the Remote 7 will function as MIDI thru ports for MRCC outputs 1-5, rather than independently routable ports.
We plan on making a custom splitter some day, but everything takes forever... so if you want to make one for yourself its pretty easy.
We used an RJ45 splitter with the mandatory shielded connectors we found in a 2 pack on Amazon.com or Banggood.com, that looks like this:
It has to have all the pins connected straight through.
A 2 pack is nice, just in case the first try doesn't work out.
This isn't an Ethernet hub or switch, don't use one of those it could damage something.
Modify the Splitter
On the side of the splitter with two RJ45 connectors, on the left side connector, use some electronics tweezers to lift 3 pins on the left side and 3 pins on the right side. Pry the pins up so they are vertical, being careful to leave the middle 2 pins intact.
Trim those 6 pins off with flush cutting wire cutters. Trim them as close to the housing as possible.
Here's how mine looks after trimming the 6 pins off, you can see the two pins left in the middle:
That's it! Now use a shielded CAT6a cable to attach the first MRCC to the single connector side of the splitter.
Attach the other MRCC using the connector where the 6 pins were removed.
Attach the Remote 7 with a shielded CAT6a cable to the connector with all the pins.
Here's mine... the white wire is going to the MRCC that will use the Remote 7 outputs. The green wire is going to a Remote 7 on my keyboard stand. The black wire is going to an MRCC in a 19 inch rack.
We tested connecting the MRCCs with shielded CAT6a cables, like the one we supply with the Remote 7. However, for a short run of 6 to 10 feet, you can probably get away with an MRCC to MRCC connection using a regular CAT5 cable if that's all you have. YMMV
The cable from MRCC to the splitter, and splitter to The Remote 7 requires the shielded cable for any length, the kind with metal shrouded connectors.
Modify the Splitter
