Midi outs
My NDLR only transmits note info on MIDI output 2 but not MIDI out 1
MIDI output 1 only transmits start/stop commands but MIDI out 1 does not.
This is definitely a flaw or defect.
(10-29-2021, 09:20 AM)KrustyRox Wrote: My NDLR only transmits note info on MIDI output 2 but not MIDI out 1
Hey Krusty,
It sounds like the NDLR is doing what it's supposed to do, but that may not be exactly what you had in mind. Since we didn't have a lot of room left for setting configuration variables we opted to set the device up to pass some data via one route and other data via another route so you can chose which way you need to use it and select the correct ports to get it going in the way you want. I included a png file of the relevant info from page 33 of the User Manual. It should provide you with the info that you need, but if you need further assistance on this please feel free to email me at Support@ConductiveLabs.com and I will get to the bottom of it with you.
Best,
Attached Files Thumbnail(s)
