It could be great to have crossfader modifier. It could fade in one CC value and fade out other CC value the same time. Using one physical knob you could change two settings at once (second in reverse way), for example:
- smooth change between two instruments playing the sequence - typical volume crossfade
- change between two values, for example LFO speed and cutoff or - nice sound morphing
- mixer channels crossfade - for example bluebox for two channels
- anything else you can imagine
