12-23-2021, 04:47 PM
		apparently the design doesn't seem to think this would ever be wanted.
In my setup I have ONE keyboard controller and go to what I want using channels. The NDLR is connected A to one synth, and B to the other. But how do i then get the keyboard which goes A-IN midi to work with the B synth? can't do it it seems. So I am moving this from SUPPORT to FET REQ.
So either I have to mult it using physical cables to double the input into A and B which probably has other bad effects... and I think it's double confusing since in the system setups there is a OUT:Midi A and B
so its confusing. Would be simpler if there was a menu choice to do this.
![[Image: attachment.php?aid=208]](https://conductivelabs.com/forum/attachment.php?aid=208)
