Could the Scale Degree buttons ( centre circle) be made to be triggerable from an external MIDI device in a way that is AWARE of scale
for example , if NDLR is set to play in C major, then the C key on my external keyboard would trigger the I ( 1st degree ) , where as if NDLR is in E major, then it would be E that triggers the 1st degree.. etc
thanks
Phill
This could be a bit complicated if I am following what you mean.
So if each chord change follows the actual scale, the user would in theory need to know the scale to change the chords, or are you saying it just starts from E and just uses the white keys?
I - E, II - F#
or
1 - E, II - F
I think if it uses the actual scale notes, it would break the simplicity of the device for those that do not know theory, as well as mess with the black keys which are used for the other chord types.
If it just starts on the keys letter and uses the white keys..... maybe, but then what happens if you're modulating the key with an LFO - you would be all over the place.
A lot of midi device that transpose, do so with a root note regardless of what's actually being played. I think on one of mine, middle C is the home un-transposed key.
I guess in terms of transposing you just have to forget about the note value and just think of C and being I, D II etc, and just an alternative to pressing the NDLRs buttons.
hi ,
to clarify, I think most of this could be overcome in design
So, taking two scales, one obvious and one not so obvious
C major and F minor,
if you wished to trigger chord changes from an external keyboard ( or in my case, a sequencer)
A NDLR set up to C major would expect the scale degrees to fall ...
I = C note ( Triggers C Major Chord)
ii = D ( Triggers D Minor Chord)
iii = E ( Triggers E Minor Chord )
IV = F ( Triggers F Major Chord)
V = G ( Triggers G Major Chord)
vi = A ( Triggers A Minor Chord)
vii = B ( Triggers B diminished chord)
where as if NDLR was set to F Natural Miinor
i = F note ( Triggers F Minor)
II -= G note ( Triggers G Major)
iii = Ab note ( Triggers Ab Minor )
...... and so on
The benifit to doing it this way , is that a monophonic external sequencer can itself play in key on its own instrument whilst also allowing for polyphonic triggering of NDLR assets....
It could , of course be a simple menu idem so that it can be toggles "scaled on of off" to allow for people with "static input devices were they would prefer to send C Major notes at all times to deal with degrees.
FM L
3
I think I see what you mean. So if I have a arturia beatstep I can use it to play the root note of the chord chosen on a synth while the NDLR is playing the notes of that chord? It makes sense but unfortunately the lack of any extra non volatile memory is preventing us from making many large scale changes to the way the NDLR functions for the most part.
It seems to me though that you wouldn't really be missing out on anything since the drone track basically does just that. Am I understanding the purpose correctly?
I'm getting what I need by sending notes (that don't go to a synth) to the NDLR to control the degree & chord shape, but it's hard work....
