06-06-2022, 06:12 AM
Hi there! I am a new Hydrasynth deluxe owner, former HS desktop owner. Hoping to hear from someone here with real HS deluxe or HS Keys experience.
I have a bunch of knob per function analog modules I use too and would love the deluxe to be my main controller. I am not fond of null patches, fiddling with settings/volumes, changing midi, etc.
I am considering an MRCC. The thought is to route midi TX to IN from the HS keybed on the MRCC and then have a flexible out as to where to send midi via all my other destinations. This would work, and it seems as if I can also turn off local on the HS deluxe and make it's IN ad RX#3 a destination I can switch to on the MRCC. I mocked this up with my keystep and I was able to control the HS from the keystep while the keybed of the HS controlled a roland module. My question: If I do this, and essentially break the local connection internally, and map it through Midi RX/TX through the MRCC,will all other HS functions work, like MPE, ribbon, poly aftertouch etc?
Thank you! This thing looks like the answer to all my challenges so I have fingers crossed and one in my cart!
