07-10-2022, 06:34 AM
There seems to he a few related posts on this topic but i am yet to find a conclusive answer. This issue has been bugging me for some time and i have reached the end of my troubleshooting tree. I want to use the NDLR in performances but it is not acting reliably for me as follows:
Basically NDLR clock is experiencing big variations on the information it sends when trying to stay in sync to midi clock from an external source. The external clock bpm is fixed.
I get the same result using din midi and now I've tried usb midi with the same issue. I use firmware 73 and intend to try 79 soon even though no specific changes seem to have been made in this area.
Clock sources have been deluge (din and usb), DJS1000 (din) and a dj controller(din) all with the same result. I have seperately verified these clocks are received by other devices without an issue and no fluctuations.
Visually on the NDLR main screen I can see the clock for an incoming bpm of 137 fluctuate between 136.7 and 137.9. On the setting page the 'Tic' indications are very irregular, sometimes two or three rapid tics at high speed and then it seems to miss one or two. I can probably provide a video if required.
Most importantly audio, it is definitely audible and some motifs seem to drift over time and essentially lag a bit and occasionally catch up. Reference to the deluge and any downstream equipment like my drum machine.
Without the NDLR my entire setup is super tight and well synced, for some reason adding NDLR into the mix upset things greatly and my suspicion is that my unit has trouble remaining synced to the clock in for some reason.
I would really appreciate any additional troubleshooting tips/methods of elimination, or any possible solutions.
Also would like to understand if other users are seeing these tic and bpm display fluctuations.
Thanks in advance
Marc H
Thanks in advance
Marc H
