08-27-2022, 09:38 PM
this is driving me crazy at the moment because it adds another level of complexity to the troubleshooting that I inevitably get into with 2 MRCCs, and now also using Kyma sending receiving midi through the computer connection.
But this is the immediate issue. One of the MRCCs will crash, or I will need to reboot it for some other reason (to recognize one of the synths that needs to be turned on FIRST.
Then things stop working. Inevitably (and i guess my brain isn't hard wired yet to look for this automatically, but, you know i don't want to have to look for this every time i have to power cycle the mrcc).
what happens is that the original instance in the audio midi set up is replaced with a new one, and ALL connections in software that I have made to that instance are not invalid. They all need to be replaced. In addition there is another display issue where they all tend to come up with the same description - in some software you can drill down and then see which is which (if you named them individually in audio midi setup) but otherwise, there are just 2 which have the exact same name, and it's kind of a guessing game.
this is really becoming a problem.
