Threads: 3
Hello
Been a while since visiting this forum. Have been enjoying Elektron’s recent Firmware updates …
And on that note; Simple question - Has the MRCC firmware addressed the issue of ‘Program Change’ that will endeavour a greater potential in conjunction with the Elektron ‘Song Mode’ … ???
Btw. I’m still on the default MRCC firmware when I received the unit a few months ago now.
Thanks
Threads: 3
03-11-2023, 11:01 PM
(This post was last modified: 03-13-2023, 09:59 PM by Pasquada.)
Thank you Jesse - will update the MRCC firmware this week.
However will the issue reg PC capabilities be addressed in near future whilst this temp workaround in employed?
If not, I’ll be left having reconsider selling off my MRCC unit and look for other alternatives for midi syncing program changes between Elektron boxes and 1010Music boxes for future live gig performance setup.
4
Sorry, not to be obtuse, are you asking if we plan on fixing the issue I discussed or another one? I am not sure I understand how the issue impacts the Elektron song mode. The main issue I have seen with Elektron boxes has to do with using incoming USB MIDI to control tempo and transport over the MRCC, this is most likely related to how they implement the USB MIDI on the device and isn't something we're likely to be able to address, but over DIN MIDI the box shouldn't have any issues. If there is another issue I'm unaware of (or simply forgot about) let me know, otherwise I think you should be able to pass PC changes without issue using the above mentioned solution.
I'm sure I can get Steve to solve the issue at some point, hopefully before too long.
Threads: 3
Jesse Johannesen
I only use DIN MIDI not USB MIDI so there should be no issue passing PC through. I use multiple Elektron boxes and Song Mode primarily uses PC messages to sync tempo and pattern changes.
