Threads: 10
Hi all,
Is there a possibility to chain chord buttons in any way? I was wondering if I could invoke a sequence like V (3 times) - VII (10 times) - II (8 times) and have the NDLR follow this pattern. Is this what Mod Destinations can be used for?
Thanks!
190531085100
For sure you can use a modulator to trigger chords. You can also create a pattern and use it as a modulation waveform for a more specific and synced chord trigger. You can also sequence chords from an external sequencer connected to a MIDI input on The NDLR.
Ultimately though, we plan to add a chord sequencer to The NDLR which will provide deliberately timed chord sequencing.
Darryl, any timeframe on when that chord sequencer update may come?
Did somebody say "Chord Sequencer?!" :o) That would be noooice!
We should have a rough idea of timing late next week.
Steve finished the MIDI Controller feature today, and started on the chord sequencer! Excited!
Threads: 10
Synthdad, thank you for the video! This is extremely helpful. The only sequencers available to me right now are the SQ-1 and the Circuit. I will try to recreate your setup.
Threads: 13
07-29-2019, 05:21 AM
Away from home at the moment so not able to try out the new features. I'm surprised there hasn't been more reaction and I'm looking forward to trying this out. I see the increments on the chord sequencer are quantised to 1/8ths. I'm curious to know how many 8ths you can choose. Does it go up to 32 or more? Presumably the note length is at present - keep playing till the next chord?
Come on you lurkers, what do you think of the chord sequencer?
